Ir para o conteúdo principal
A 6ª revisão da Apple para a linha iPod Touch, lançada em julho de 2015.
Will not turn on
My iPod touch was working fine and the battery was charged well. I pushed the standby button and when I tried a few minutes later to turn it on, nothing happened. I connected it to my desktop computer and it was not recognized by the computer and still it would not turn on.
Esta é uma boa pergunta?
Pontuação 49
11 comentários
what if the home button does not work? how to soft reset.
por
Thank you sooooo much. You made my little girl jump out of her chair and do the happy dace.
por
My iPod will not turn on, I had put it in a safe for 2 months and after it won't charge or turn on can someone plz help
por
Jacob try leaving it on charge it might just be the battery is dead flat
por
I had this problem but I found that since updating to the latest iOS 10.1.1 I have not had this problem anymore
por
Exibir mais 6 comentários
Adicionar um comentário
11 respostas
Solução escolhida
Have you tried a soft reset? Hold both power button and home button for 15 seconds.
Esta resposta foi útil?
Pontuação 84
76 comentários:
You my sir are a life saver
por
Oh my god I love you this helped so much
por
OMG!!!! Thank you so much! I almost panicked! Thank you! Thank you! :D
por
thank you very much!!!!!!!!
por
Definitly the most helpful answer
por
Exibir mais 71 comentários
I did the soft reset for 15 seconds... It didn't work, it then tried 40 seconds and the apple logo suddenly appeared, if your iPod is uncharged a symbol showing a low battery should appear on your screen ☺️
Pontuação 13
11 comentários:
I have often used the 15 sec tricks. Good idea to be à little bit more patient ;-) After 50 some seconds a looooow battery icon was showing. Merci !
por
Took me 40 seconds and I made sure to press down hard. Thank the lordy. Apple comes through again!
por
thanks-that really helped=made Christmas merry!
por
I finally got a low battery to show after 50 sec hold on the two buttons. How do I find someone to help replace the battery?
por
I appreciate it. Patience ended up winning out in the end on multiple units that I was told were dead. Thank you
por
If your computer doesn't recognize it then that means that your battery is probably bad.
Pontuação 4
4 comentários:
Yer well u can't open the back so how do u no there is even a battery
por
@albert Einstein *facepalm* of course there's a battery......
por
omg you are awesome
por
thank you!!!!! you just made my day it really worked
por
If it's a 6th Gen touch it should still be under warranty. Get it back to Apple for repair or replacement.
Pontuação 3
Try soft reset! This helped me today. I got up, unplugged my iPod 6th generation and was going to take it to school but I went back into my room to get it and it wouldn't turn on. I freaked out and I tried calling my mom but she didn't answer cause she was at work so I wrote on the white board saying that my iPod wouldn't turn on and my parents saw it well I was at school. When I got home I saw my case on the table with my iPad mini and my parents were yelling at me. I wanted to prove to them that I am responsible so on my iPad mini I looked up a bunch and I found this soft reset thing. (How to soft reset: hold down the home button and power button at the same time for 15 seconds.) if this doesn't work then return it, or take it to a Apple Store. Sorry for telling my story from this morning and afternoon XD
Pontuação 3
Hey Galin Halimar,
So sad the soft reset didn't worked :-(
But the end of the world is not there yet!
You must replace the battery, it's probably bad.
Here's the part and the guide, stop by step 22 and work backwards.
iPod touch (6th and 7th Gen) Battery
Substituição da carcaça traseira do iPod Touch 6ª Geração
Imagem de Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V).
Produto
$19.99
Pontuação 3
Help!!!!!
My ipod touch 6th gen won't charge it has a blue screen when i plug it in what do I do?!?!?!?
Ps I've already tied the holding the home and on off buttons it doesn't work and I have school tomorrow and I just got it last year for my birthday.
Can someone please help me??
Pontuação 1
1 comentário:
Also when I try to plug it into my computer it doesn't recognize my ipod
por
did a soft reset with it plugged into the computer and its back to life thanks
Pontuação 0
1 comentário:
Thanks a lot it really worked. I did the soft reset with it plugged in.
por
U have to hold power button and home button for like 10 secs and should turn on.
Pontuação 0
my ipod doesnt want turn its been 8 days keep black screen
Pontuação 0
3 comentários:
Yeah mine has been like it for a day now
por
Mines been like that for maybe 4 to 5 months cause some guy puts his stuff on top of it and it just went black and won't turn on. I tried to connect it to my computer. I tried the soft restart. I tried everything and it still won't work. I might have to takemit to the Apple store for repairment to get it working again. And I also tried the IOS as well but no reconigization for it either.
por
And I literally just got for Christmas too
por
My iPod Touch 6th Gen was dropped in water now won’t turn on can it be fixed?
Pontuação 0
1 comentário:
Kbrick, I don't think the Ipod 6 works if you drop it in water. Minor issues, like a few drops dripped onto it or you used a wet tissue to wash the screen is fine. But major issues probably won't end so well.
por
Adicionar a sua resposta
Galen Halimar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 52
Ao todo: 72,170
