Ir para o conteúdo principal
A versão de 1998 é baseada no Beetle original, mas, em comparação com o modelo antigo do veículo, é muito mais espaçosa e equipada com recursos mais avançados.
Trunk will not open at all
I have a 2003 VW Beetle Convertible. The trunk latch is broken. I cannot open the trunk with remote or key. I opened the rear seat to gain access to the trunk, reach my arm in and the latch is broken. I know this because when I pull on the latch mechanism, it's frozen, will not move at all. Any suggestions on how to get into trunk when latch is broken in the closed position?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
The info in this link may be of interest
http://newbeetle.org/forums/new-beetle-c...
Esta resposta foi útil?
Pontuação 4
2 comentários:
It's a really tight fit. In fact the only way I can work on the trunk from the inside is with one arm reaching into the trunk area, rest of my body outside on the back seat. I discovered a round (almost invisible) cap of sorts inside the trunk below and to the right of the emergency release level. From the article you attached I see that this should be another release (a more effective one). I will try it later today. Thank you for the article.
por
This does NOT work for an 2003 Beetle 1.8T.
por
Adicionar a sua resposta
Jim será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 81
Ao todo: 45,864
