Ir para o conteúdo principal
A GoPro Hero3+ Silver Edition (modelo nº CHDHN-302) foi lançada em outubro de 2013. Esta filmadora digital é capaz de gravar vídeos em resolução 1080p HD e tirar fotos de 8 MP.
Why does the video recording randomly stop?
Occasionally my GoPro will stop recording in the middle of a shot. I often don't know which videos stopped recording until later when I go through the footage. Is there anything I can do so that the recording doesn't stop?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
When using a micro SD card, it will fragment over time no matter how much storage it has. This means that you can have no files on your SD card and yet this fragmenting will interrupt the high transfer rates required to film in such high resolutions.
To fix this problem, you can reformat your SD card, giving you a completely blank SD card to work with. This should allow you to film in high resolutions. To reformat your SD card, delete all the files off of it, and reinsert it into your GoPro. This should fix any problems you have. For more information regarding this problem, see the link below.
GoPro Hero3+ Silver Edition Troubleshooting
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Patrick Cook será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 2,331
