Ir para o conteúdo principal
Why there is a black spot and line on the display?
Hi,
Today just appeared a black spot and line on the display.
This display was replaced 6 months ago and now is presenting this spots.
Which could be the reason of this spots and how can be fix?
Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Huh, that is weird. Doesn't usually show up like that. It's damage to your lcd.
iPhone 6 LCD and Digitizer
Substituição do conjunto do painel dianteiro do iPhone 6
Imagem de iPhone 6 LCD and Digitizer
Produto
$69.99
Esta resposta foi útil?
Pontuação 1
You've damaged the LCD panel, looks to be an impact mark, just follow the guides listed by @imedicminneapolis above !!!
Best of luck
Regards
Pontuação 1
Defiantly damage, as the above guys said!
Pontuação 0
Adicionar a sua resposta
charlies8 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,579
