Ir para o conteúdo principal
O Lenovo G570 é um laptop de 15 polegadas anunciado em janeiro de 2011.
My laptop screen cannot light up.
I accidentally pressed the connect to projector and clicked projector only. SSo eversince my laptop screen has been blank. It does switch on only that the screen is black. Its not connected to a projector so how can i fix it? Please Help me.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Start your PC in Safe Mode
To start your PC in Safe Mode start tapping the F8 key as soon as your manufacturer’s logo appears. This will open the Windows Advanced Options Menu] •If you begin tapping the F8 key too soon, some computers display a "keyboard error" message or start beeping. To resolve this, pause tapping F8 for 1-2 seconds then start tapping again•If you see the Windows logo, it means you did not start pressing the F8 button soon enough. You will need to reboot and try again.
An advanced options window will open. Select "Safe Mode" by using the Up/Down arrow keys on your keyboard, then press enter.
Wait for Windows to load.
Regular Safe Mode will open Windows with minimal drivers and no internet connection. This is the most recommended method for dealing with viruses and other malware.
When Windows has loaded the desktop will have "safe mode" written in each corner.
Next navigate to Start---- Control Panel----Appearance and Personalization, click on adjust screen resolution.
This is where you should be able to select which display you want. Make the change, click save then restart your PC
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Amelia Jones será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 736
