Ir para o conteúdo principal
The Summer Infant 3D Lite is a stroller that features an ultra-lightweight design and easy storage capabilities.
8 Perguntas Visualizar todos
Why is my wheel not touching the ground?
Once all the wheels have been placed, they are not balancing properly and one is unable to touch the ground. How can I fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
If the wheels are not all touching the ground, check if the wheels have been properly installed. The front wheels should have arrows on them that both point up, and the back wheels brakes should flip downward. If one of the wheels is not properly installed, just press the silver pin and pull the wheel to remove it, and install it the correct way. Refer to either the front wheel guide or the back wheel guide for more information on replacing the wheels.
Imagem de Summer 3D Lite Convenience Stroller Back Wheel
Guia
Summer 3D Lite Convenience Stroller Back Wheel Replacement
Nível de dificuldade:
Fácil
10 minutes
Imagem de Summer 3D Lite Convenience Stroller Front Wheel
Guia
Summer 3D Lite Convenience Stroller Front Wheel Replacement
Fácil
2 minutes
Esta resposta foi útil?
Pontuação 0
1 comentário:
Add a link to the guide.
por
I need a new wheels because is very dificult move the strolker. Where can I buy the front wheels?Thanks
Pontuação 0
Adicionar a sua resposta
Nick Taylor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 77
Duração total: 14,765
