Ir para o conteúdo principal
Summer 3D Lite Convenience Stroller Back Wheel Replacement
  1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: passo 1, imagem 1 %32 Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: passo 1, imagem 2 %32
    • Set the stroller up so the front wheel is on the ground with the metal push tab up.
  2. Summer 3D Lite Convenience Stroller Back Wheel Replacement: passo 2, imagem 1 %32 Summer 3D Lite Convenience Stroller Back Wheel Replacement: passo 2, imagem 2 %32
    • Push the tab in with your finger enough so the plastic can slip out above the tab.
  3. Summer 3D Lite Convenience Stroller Back Wheel Replacement: passo 3, imagem 1 %32
    • OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
  4. Summer 3D Lite Convenience Stroller Back Wheel Replacement: passo 4, imagem 1 %32
    • The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
Conclusão
4 outras pessoas executaram este guia.
Nick Taylor
Membro desde: 09/28/15
188 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-5, Forte Fall 2015 Membro de Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
Membros da 4
Autoria de 3 guias
Um comentário
Gd, have a question . Were can u buy spare parts for this type of stroller?
pieterroos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 108
Duração total: 10,579
