Ir para o conteúdo principal
Summer 3D Lite Convenience Stroller Front Wheel Replacement
O que você precisa
  1. Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: passo 1, imagem 1 %32 Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: passo 1, imagem 2 %32
    • Locate the black plastic tabs on the front wheel. There should be two, opposite sides from each other.
  2. Summer 3D Lite Convenience Stroller Front Wheel Replacement: passo 2, imagem 1 %32 Summer 3D Lite Convenience Stroller Front Wheel Replacement: passo 2, imagem 2 %32
    • Firmly press both tabs inwards, and use your other hand to pull the wheel off
Conclusão
7 outras pessoas executaram este guia.
Tyler Haugland
Membro desde: 09/28/15
311 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-5, Forte Fall 2015 Membro de Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
Membros da 4
Autoria de 3 guias
14 comentários
How can i order the front wheels
Amalia Ontiveros - Responder
Hi, you can contact the Summer Infant Consumer Relations Team by calling 800-268-6237, Monday-Thursday, 8:00am-6:00pm EST and Friday 8am-3pm EST.
Stroller Guy -
I think there should be a video tutorial for this product. thank you!!
Lisa D. Richards - Responder
Yes i think there should be a video
yummy mummy fantom XXX -
The Front wheel is less bending in the axis, how to make straight by hand
Samson Wong - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 36
Últimos 30 dias: 174
Duração total: 54,025
