Ir para o conteúdo principal
Um PC Samsung Série 3, o NP300E5C-A09US é um notebook de 15 polegadas com uma resolução de tela de 1366x768. É uma ótima opção para quem procura um computador portátil leve e, ao mesmo tempo, potente.
How do I fix my screen?
My screen isn't working right! My screen is showing big blotches of black and white, and vertical lines with different colors, like a rainbow. How do I fix my screen?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Solução escolhida
Ahsan, from your description it sounds like you need to replace your screen. A guide for this can be found here: Substituição da tela do Samsung NP300E5C
Esta resposta foi útil?
Pontuação 1
aliahsan95, from your description (consider adding images of what you see with your question use this guide for that), it sounds like you have a broken LCD. This video will help with the replacement.
Pontuação 0
PLEASE IF YOUR NOT A PROFESSIONAL OR A PERSON THAT DOSEN'T UNDERSTAND TECHNOLOGY DO NOT ATTEMPT FIND A PROFESSIONAL THAT CAN DO IT!
{TIPS WOULD BE TAKE PICTURES THROUGH EVERY PROCESS HAVE A NON CONDUCTIVE WORK SPACE (STATIC ELECTRICTITY)}
1.You need to source the part you need.
2. Type the model number on eBay with full assembly screen
3a. If your screen comes up with the bezel and everything buy it and continue on to 4a.
3b. If it comes up but it looks like the screen but its got no bezel or housing try to ignore and try to find (3a.) buit if your willing to try continue to 4b.
3c. If nothing come up it's time to get a new laptop
4a.Once the screen arrives IMMEDIATELY CHECK FOR DAMAGE so you can return it and get another one or get a refund from the seller! If its all good disassemble the old laptop until you run into where the screen is connected (typically snap connectors or latch connectors) {Tip: look at what the parts connectors look like} Then i HIGHLY Advise you to plug in the new screen and check and see if its working fine (yes with the old screen still attached!) If its BAD (RETURN IT) If its GOOD continue by detaching the new screen and now unhinging the old screen usually held by screws and then place the new screen in the old spot screw everything back together and connect everything! continue to step 5!
4b.IF all you can find is just the lcd your going to need to split the old bezel holding onto the old lcd and usually you can find a youtube video on how to pry or lift the two apart! (BUT BEFORE YOU DO THAT YOU NEED TO CHECK THE LCD BY UNPLUGING THE OLD ONE AND CONNECTING THE NEW ONE WITH THE OLD ONE STIL ATTACHED TO TEST IT!) once the bezel is in half remove the old lcd and place the new one inside like how the old one looked! then snap the bezel back together and you can continue connecting and screwing everything back together! Continue to 5!
5.YOUR DONE :)
Pontuação -1
Adicionar a sua resposta
aliahsan95 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 1,024
