Ir para o conteúdo principal
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
20 Perguntas Visualizar todos
not charging the battery
battery is still good but phone does charge it.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
tomasulang2006, try a different charger and a different cable. If that does not work you will have to take a closer look at the charging port. Disassemble your phone using this guide and check your charging port. I'd replace that, but it is soldered to the board so you will need some soldering tools and skills.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
tomasulang2006 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 63
