phone got wet how do I get it to work again
Esta é uma boa pergunta?
betty brown, you will have to clean it just like any other phone. Skip any thought (or anything you may have read)you have had about using rice :-). It does not do anything other than give you a false sense of security. You do not want try to restart the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using this guide Then clean it with +90% isopropyl alcohol. Follow this guide, and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. Water damage is the hardest to diagnose since virtually any pat may have failed. Even with all the steps above, there is still a chance that your phone is irrepairable. Hope this helps, good luck.
Guia
Nível de dificuldade:
Difícil
1 - 2 hours
Guia
Difícil
30 minutes - 1 hour
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 61
