Ir para o conteúdo principal
Um Windows phone conhecido pelos seus recursos de câmera. Também conhecido como Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
Phone not switching on
I was using my phone and then it got switched off due to no charge.
I kept it for charging and tried to switch on my phone but since then its not switched on.
It wont switch on due to some reason.Kindly help.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Fazal, it is possible that it is just totally discharged. Try a new cable and a different charger. If that does not work, you may have a bad charging connector. In that case, try a new battery or one that has been charged with an external charger to at least get your phone to respond. Consider replacing the charging port. Here is a decent guide for that.
Esta resposta foi útil?
Pontuação 0
1 comentário:
That video is in no way helpful it doesn't show u how to remove the port I went through the steps a few minutes ago after releasing the 2 screws there is still another part of the flex cable which is behind the speaker and to remove the speaker u would have to break the backcase so my suggestion is to by the back case with the port
por
Adicionar a sua resposta
Fazal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 1,015
