Ir para o conteúdo principal
A baby monitor made by Infant Optics, Inc. The DXR-8 features a 3.5" screen , temperature sensor, night vision, and an interchangeable lens system.
How do I replace the speaker in my baby monitor?
My monitor is having audio issues. Is it possible to replace the speakers?
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Larsha Johnson, another writing assignment where you answer your own question:-)? Best of luck to you
por
Adicionar um comentário
2 respostas
If your speaker is blown, then you can replace it by following this guide for step by step instruction to replace the faulty speaker.
Check out the Infant Optics DXR-8 Troubleshooting Page for further help.
Esta resposta foi útil?
Pontuação 0
How do you open the casing and where can you buy a replacement speaker?
Pontuação 0
1 comentário:
I can answer the first question at least. The casing is opened by removing plastic face. Insert something firm and slim in between the front of the monitor and the tiny led charging light. Slowly work around the sides loosening the glue holding it down until the entire face pops off. There are screws underneath that hold the case together.
por
Adicionar a sua resposta
Larsha Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 3,958
