Ir para o conteúdo principal
Infant Optics DXR-8 Speaker Replacement
O que você precisa
    1. Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: passo 1, imagem 1 %32 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: passo 1, imagem 2 %32 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: passo 1, imagem 3 %32
      • Using the plastic opening tool, remove screen protector from front of monitor.
      Pergunte ao FixBot
      Comentar
    2. Infant Optics DXR-8 Speaker Replacement: passo 2, imagem 1 %32 Infant Optics DXR-8 Speaker Replacement: passo 2, imagem 2 %32 Infant Optics DXR-8 Speaker Replacement: passo 2, imagem 3 %32
      • Remove the six 4mm screws using a Phillips #00 screwdriver.
      • Remove the screen, exposing the circuit board.
      • Turn device over to expose rear circuit board.
      Pergunte ao FixBot
      Comentar
    3. Infant Optics DXR-8 Speaker Replacement: passo 3, imagem 1 %32 Infant Optics DXR-8 Speaker Replacement: passo 3, imagem 2 %32 Infant Optics DXR-8 Speaker Replacement: passo 3, imagem 3 %32
      • Disconnect speaker from monitor for ease of access by unplugging wire.
      Pergunte ao FixBot
      Comentar
    1. Infant Optics DXR-8 Speaker Replacement, Speaker: passo 4, imagem 1 %32
      • Use a heat gun to soften and easily remove epoxy that surrounds the speaker. Gently scrape it free little by little with metal spudger.
      Pergunte ao FixBot
      Comentar
    2. Infant Optics DXR-8 Speaker Replacement: passo 5, imagem 1 %32
      • Lift the speaker from casing using metal spudger.
      • Place new 8W speaker in the casing and connect wire.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 6-4, Remmell Fall 2015 Membro de USF Tampa, Team 6-4, Remmell Fall 2015
USFT-REMMELL-F15S6G4
4 Membros
Autoria de 12 guias
5Comentários do guia
Where to purchase the replacement speaker?
Keiundra Joiner - Responder Compartilhar
Where can we purchase the replacement 8w speaker part
lea placek - Responder Compartilhar
8W Speaker is incorrect.
The speaker needed is 8 Ohm 0.5 Watt.
Ryan Ernde - Responder Compartilhar
Thanks for this. Found something on Ali Express, just need to figure out the right size
https://www.aliexpress.us/item/325680361...
itryit - Responder Compartilhar
This is good to show how you get it open. Unless you have a speaker that has the plastic piece that connects to the mother board, then it’s useless. The speaker I ordered just had two free standing wires.
Mark Ruddy - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 85
Ao todo: 18,507
