Where is horn located
Where is horn located on a 2003 chevy cavalier
Esta é uma boa pergunta?
Have someone blow it and follow the sound. If it doesnt work and your looking to fix it the horn itself is probably the last thing that goes wrong . Check your fuses and as is with most horn problems check the pressure pad in the steering wheel. this is the most common problem with horns.
Esta resposta foi útil?
jtorres12396, you will find the horn on the bottom right front under the fender
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 12
Duração total: 2,515
