Ir para o conteúdo principal
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139 Perguntas Visualizar todos
Where is horn located
Where is horn located on a 2003 chevy cavalier
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Have someone blow it and follow the sound. If it doesnt work and your looking to fix it the horn itself is probably the last thing that goes wrong . Check your fuses and as is with most horn problems check the pressure pad in the steering wheel. this is the most common problem with horns.
Esta resposta foi útil?
Pontuação 2
jtorres12396, you will find the horn on the bottom right front under the fender
Pontuação 0
Adicionar a sua resposta
jtorres12396 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 12
Duração total: 2,515
