Ir para o conteúdo principal
Apple iPad de primeira geração com Wi-Fi, disponível com 16, 32 ou 64 GB. Modelo número A1219. Os reparos são simples e não exigem aquecimento.
20 Perguntas Visualizar todos
unknown error occured 1671
cant open or close ipad
Esta é uma boa pergunta?
Pontuação 15
1 comentário
1. Update iTunes to the latest version to ensure that it is compatible with the version of IOS and the iDevice with which we are working.
2. Update the antivirus and run a full system scan for infections.
3. Install the latest version of the computer operating system.
4. Connect the iPhone or iPod Touch to a high-speed USB port (USB 2.0 or higher).
5. How to Solve an Unknown Error 1671 Occurred on iPad
por
Adicionar um comentário
6 respostas
Pergunta mais útil
iphone itunes error 1671
Esta resposta foi útil?
Pontuação 2
non riesco ad usare i pad
Pontuação 1
2 comentários:
my ipad was not restore and not updating
it's showing the only showing itunes simble
por
my ipad showing the an error occurred 1671
por
did this error occur during a update?
try
Resolve iOS update and restore errors in iTunes
Resolve issues with an over-the-air iOS update
Pontuação 0
6 comentários:
no
flickered and went to iTunes logo with charging pix
por
wont turn on or off tried the iTunes restore
por
So you see the itunes logo on the ipad and when connected it and tried to restore it you got 1671?
Try to restore the ipad in DFU Mode:
Step 1: Turn off your iPod touch / iPhone completely and connect to PC / mac
Step 2: Hold down the Power button for 3 seconds
Step 3: Without releasing the power button, also hold the Home button for 10 seconds
Step 4: Without releasing the home button, release the power button and keep holding the Home button for 20 seconds.
por
Sometimes you need to update or restore your iOS device and for this purpose you use iTunes applications. To transfer, restore, update iOS devices you simply need to connect your device to computer using USB cable and while going through some of the above activities it shows iTunes error 1671. It generally happens due to incompatible version of the iTunes or iTunes components are corrupt or damaged USB cable.
http://www.iosdevicerecovery.info/blog/c...
por
Johnny Martini - Thank you. The following fixed the 1671 error for my iPad.
por
Exibir mais 1 comentário
none of these ideas work
Pontuação 0
I had the same issues and it ended up being iTunes was still downloading software for the update. I don't have a clue why it prompted me to continue the update when it was still downloading. Look in the upper right-hand side of iTunes for the square box which has the downloading indicator on it. Make sure it's still not downloading before reacting to the prompts. Once it was done, I was clear for takeoff! Hope this helps some of you.
Pontuação 0
John martini's workflow solved my problem: apple 0: ifixit: 1 yay
Pontuação 0
Adicionar a sua resposta
casinorat1968 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 48,225
