Ir para o conteúdo principal
Um tablet de 10,1 polegadas da Samsung com processador de 1,4 GHz, tela LCD de 1280x800 pixels e display multitoque de 149 ppi. O número de modelo do dispositivo é GT-N8013ZW. Lançado em agosto de 2012, o reparo deste dispositivo é simples.
Replaced LCD - Did not work.
My screen was displaying colors similar to 256k. White was teal, black was red, etc, and ghosting. Per iFixit.com; this would be the LCD. I purchased a replacement LCD from iFixit.com, and completed the repair (I am competent in the area of electronics). However, the new LCD is displaying similar issues, just not as bad. The new LCD is an improvement, but not what anyone would consider operating as it should.
The LCD supplied was "used" previously as noted on the website, and I was aware of this - but appears that the replacement LCD was defective prior to shipment. My question is this; when purchasing a product from iFixit.com - and it does not adequately address the issue, what can be done?
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Hey CF,
I replaced the entire LCD based on the suggestions on the iFix site. The odd thing is that the tablet was working fine one evening; then the next morning - it was messed up. I've contacted customer support and once I get a resolution and the tablet is working as it should, I will post what it was that resolved this.
por Compartilhar
Adicionar um comentário
1 resposta
I am having the same issue,(black is red) previously I was able to knock it around and it would fix itself. But I can no longer do that.
Did you purchase the LCD ribbon ? Or was it the entire LCD replacement?
If you find a solution, would you be able to post it?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
hockerst será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 484
