A dirty coil is the first thing to check and you did.
Evaporator Fan Motor
How it Works:
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
How it Works:
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
How it Works:
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
How it Works:
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
How it Works:
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
How it Works:
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
How it Works:
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
How it Works:
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
How it Works:
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
5 comentários
I have a similar issue. I have a Whirlpool w10307496b. The freezer and the fridge side are not working. The fan near the compressor is not running. To this point I have changed the compressor relay, capacitor and fan motor. The coils were very dusty. I have cleaned those as well. It still isn't working. What could be the problem?
por Jerry Reyes
Computer board
por Pete Clark
H I have a daewoo side by side fridge/freezer . The fridge side is warm but freezer seems ok ?
por Lisa kelly
Hi @leyland73 ,
What is the model number of the refrigerator?
What are the actual temperatures in the fridge section and the freezer section?
Can you hear a fan running inside the freezer compartment? It will stop when you open a door and start again when the door is closed. It should be running if the compressor is running. You may have to place an ear against the fridge to hear it.
por jayeff
I suppose you have set your temperature to a sensible rate. If the compressor is in fact working, you may have a gas leak within the pipes or you need a refill. Finding leaks is not easy but I figure that using the old hole in the bicycle inner tube repair might work. You will need to create a vacuum within the pipes prior to refilling the gas. Add soapy water to all pipes and have lot of patience to find where the bubbles form and weld that spot. Otherwise, there are companies that can do this for you and I don't think it's too expensive.
por Funk Addict
