Ir para o conteúdo principal
O Pontiac Sunfire 2000–2002 é um modelo sedã.
How do I remove the dashboard?
I have been trying to find a helpful guide to remove the dash from my 2001 4 -door Sunfire. I want to access the radio and AC.
I am looking for a very thorough walk-through, I need to be able to dismantle the dash and put it back together in as little time as possible. I can't be without a car because a step was skipped.
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
gatewaynomad, take a look on here
Esta resposta foi útil?
Pontuação 1
3 comentários:
It doesn't mention anything about the anti-theft system, any idea if that comes into play?
por
It shouldn't, but do have to admit that I am not sure. You may have to check it out and see what happens. What are you trying to accomplish anyway?
por
The FM on my radio has stopped working. AM works and CD player work, but the FM is silent.
I took the radio out, and checked the cable for the antenna. When I remove it, FM gets snow. When I put it back in, it is silent or has a very low sound that may be voices. So, now I know that the a simple disconnect isn't the issue.
por
Adicionar a sua resposta
gatewaynomad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 2,079
