Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
How to locate power pads on A1398
mac book pro will not power up via keyboard. Are there any power pads on this model rather than having to short out the #5 and #29 on the keyboard ribbon, I am finding it almost impossible to do on the ribbon because it is so small. I'm not entirely sure if it should be the 5th from the left or the right (I have my mac back off and I see the fans at bottom and the batteries at the top.) How many pins should I see ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
audreyc79, even this board has power on pads. They are used for debugging the hardware, not for routine power-on purpose of course. Just apply a jumper across the pads for a brief time.
Esta resposta foi útil?
Pontuação 2
1 comentário:
not on this A1398
por
power pads on this are your CHARGER, this is supposed to automatically turn on when you plug your charger in.
Pontuação 0
1 comentário:
True That!!!!!!!!
por
My a1398 dont have this power pads.. How can I locate?
Pontuação 0
A1398, Mid-2015 power pads location:
Pontuação 0
Adicionar a sua resposta
audreyc79 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 26
Ao todo: 3,115
