Ir para o conteúdo principal
The economical version of the Samsung Galaxy S4, released in July 2013.
20 Perguntas Visualizar todos
Wet phone. can it be fixed?
Wet phone. Jumped in pool and forgot phone in pocket. Can it be fixed.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
jonelesuma, sometimes it can. I suggest that the very first thing you want to do is to not try to restart the phone. This may further damage your phone. You also do not want to try to charge it any further. The next thing to do is to clean it. Disassemble your phone using this video Once it is disassembled, you do need to clean it properly. You will need high grade isopropyl alcohol and a soft brush. Use this guide to see how to clean it. Even so it was written for a 3G all the points are still pertinent to your phone. While you are cleaning it, check for any broken, missing or burned looking components. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate.Water damage is the hardest to diagnose and the toughest to repair since virtually any part may have failed." Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jonelesuma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 277
