Is this for the upstream sensor or the downstream sensor
When I had a scan check down on my car, it came back with a p0131 code. Is this for the upstream sensor or the downstream sensor or both?
Esta é uma boa pergunta?
Ken Cappon, there are a few causes for the P0131 code:
- Faulty Front Heated Oxygen Sensor (HO2S) Bank 1
- Front Heated Oxygen Sensor (HO2S) Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor (HO2S) Bank 1 circuit poor electrical connection
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks from here
Replacing the Front Heated Oxygen Sensor (HO2S) Bank 1 usually takes care of the problem.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 748
