Washer will not drain after wash cycle?
Tried Spin cycle several times.
Esta é uma boa pergunta?
Ken, if it sits there waiting to drain, check to see if it is absolutely silent or if you can hear a hum. If it hums it could be something stuck in the drain pump or you may have a defective drain pump. Check on here how to replace the pump. If it does not hum then the problem is more likely the lid switch.
Esta resposta foi útil?
Good answer!
You saved my day!
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 7
Duração total: 2,385
