Ir para o conteúdo principal
O Asus Zenbook UX31A é um laptop lançado em junho de 2012. Ele é um membro da linha Ultrabook da Asus. Possui um processador Intel Core I7 de 3ª geração e uma tela IPS Full HD.
How to fix power button?
My problem is that I can't turn my Asus on.
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
2 respostas
It is most probably this problem :
Conserto de teclado sem resposta
See also :
Solução para o teclado do Asus Zenbook UX31A que não responde
Imagem de Asus Zenbook UX31A
Guia
Nível de dificuldade:
Fácil
10 minutes
Guia
Fácil
15 minutes
Esta resposta foi útil?
Pontuação 0
If you may have slipped any liquid on the keyboard, it may become not responsive. As the only option to power up the laptop is via pressing the 'power' button on the internal keyboard, you won't be able to turn on the laptop.
Removing and cleaning the keyboard may help but not necessarily -- this laptop's keyboard is a thin thing and you can't really clean 'in-between' its layers.
You may want to replace the keyboard as the first option.
Or if you reasonably suspect that the liquid could have gotten further down from the keyboard unit, you may want to 'ring-out' your motherboard first.
As to me, I've firstly checked that the motherboard was OK, then replaced the keyboard. Everything started to work as a chime.
If your keyboard works but the touchpad doesn't - check that the touchpad wire is firmly connected (from memory, to the back of the keyboard rather than to the motherboard -- but I can't remember for sure). Sometimes the connection gets lose (and may especially get lose while you are working on replacing the keyboard).
Pontuação 0
Adicionar a sua resposta
Dai Quy Phan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 10,639
