Ir para o conteúdo principal
Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
It is possible to just replace fan
My son has a x box 360E the cooling fan is making noise, and will prevent the console from being used. Is it possible to just replacement the fan? Do we HAVE to buy special tools to make the change, or are we able to use small screw drivers and tools non specific to x box?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
yes you can replace it
por
Adicionar um comentário
1 resposta
Solução escolhida
aloram85, you will need a T6,T9, and T10 screwdriver. Use this guide to get to the fan.
Esta resposta foi útil?
Pontuação 3
1 comentário:
I would not just replace the fan as it is often a problem with fan-cooled-devices that it is running too fast, because of dust sitting in the heat sink or new thermal grease needs to be applied onto the cpu of the xbox. There are many videos on youtube how to do this! Such as this one:
https://www.youtube.com/watch?v=nFc7imbB...
In my case it already helped to use a high pressure spray by spraying into the fan of the xbox. So probably it wasn't a thermal-grease-problem ;)
por
Adicionar a sua resposta
aloram85 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 38
Ao todo: 5,279
