Ir para o conteúdo principal
Xbox 360 E Motherboard Replacement
O que você precisa
  1. Xbox 360 E Motherboard Replacement, Top Panel: passo 1, imagem 1 %32
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    Pergunte ao FixBot
    Comentar
  2. Xbox 360 E Motherboard Replacement: passo 2, imagem 1 %32
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    Pergunte ao FixBot
    Comentar
  3. Xbox 360 E Motherboard Replacement: passo 3, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 3, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 3, imagem 3 %32
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
    Pergunte ao FixBot
    Comentar
  4. Xbox 360 E Motherboard Replacement, Bottom Panel: passo 4, imagem 1 %32
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
    Pergunte ao FixBot
    Comentar
  5. Xbox 360 E Motherboard Replacement: passo 5, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 5, imagem 2 %32
    • Slide the spudger along the crevice to separate the grated face and the top body.
    Pergunte ao FixBot
    Comentar
  6. Xbox 360 E Motherboard Replacement: passo 6, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 6, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 6, imagem 3 %32
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
    Pergunte ao FixBot
    Comentar
  7. Xbox 360 E Motherboard Replacement, Front Panel: passo 7, imagem 1 %32 Xbox 360 E Motherboard Replacement, Front Panel: passo 7, imagem 2 %32 Xbox 360 E Motherboard Replacement, Front Panel: passo 7, imagem 3 %32
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
    Pergunte ao FixBot
    Comentar
  8. Xbox 360 E Motherboard Replacement: passo 8, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 8, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 8, imagem 3 %32
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
    Pergunte ao FixBot
    Comentar
  9. Xbox 360 E Motherboard Replacement: passo 9, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 9, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 9, imagem 3 %32
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    Pergunte ao FixBot
    Comentar
  10. Xbox 360 E Motherboard Replacement: passo 10, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 10, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 10, imagem 3 %32
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
    Pergunte ao FixBot
    Comentar
  11. Xbox 360 E Motherboard Replacement: passo 11, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 11, imagem 2 %32
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
    Pergunte ao FixBot
    Comentar
  12. Xbox 360 E Motherboard Replacement: passo 12, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 12, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 12, imagem 3 %32
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
    Pergunte ao FixBot
    Comentar
  13. Xbox 360 E Motherboard Replacement, RF Module: passo 13, imagem 1 %32 Xbox 360 E Motherboard Replacement, RF Module: passo 13, imagem 2 %32 Xbox 360 E Motherboard Replacement, RF Module: passo 13, imagem 3 %32
    • Looking at the body of the device, locate the green panel to the right of the CD drive.
    • Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver.
    • Grip the middle of the green board and gently pull it out.
    Pergunte ao FixBot
    Comentar
  14. Xbox 360 E Motherboard Replacement, Wi-Fi Card: passo 14, imagem 1 %32
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
    Pergunte ao FixBot
    Comentar
  15. Xbox 360 E Motherboard Replacement: passo 15, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 15, imagem 2 %32
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
    Pergunte ao FixBot
    Comentar
  16. Xbox 360 E Motherboard Replacement, Bottom Body: passo 16, imagem 1 %32 Xbox 360 E Motherboard Replacement, Bottom Body: passo 16, imagem 2 %32 Xbox 360 E Motherboard Replacement, Bottom Body: passo 16, imagem 3 %32
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
    Pergunte ao FixBot
    Comentar
  17. Xbox 360 E Motherboard Replacement: passo 17, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 17, imagem 2 %32
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
    Pergunte ao FixBot
    Comentar
  18. Xbox 360 E Motherboard Replacement: passo 18, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 18, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 18, imagem 3 %32
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
    Pergunte ao FixBot
    Comentar
  19. Xbox 360 E Motherboard Replacement: passo 19, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 19, imagem 2 %32
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
    Pergunte ao FixBot
    Comentar
  20. Xbox 360 E Motherboard Replacement, Top Body: passo 20, imagem 1 %32 Xbox 360 E Motherboard Replacement, Top Body: passo 20, imagem 2 %32
    • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
    • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
    Pergunte ao FixBot
    Comentar
  21. Xbox 360 E Motherboard Replacement, CD Drive: passo 21, imagem 1 %32 Xbox 360 E Motherboard Replacement, CD Drive: passo 21, imagem 2 %32
    • Use your fingers to unplug the blue ribbon cable from the CD drive.
    Pergunte ao FixBot
    Comentar
  22. Xbox 360 E Motherboard Replacement: passo 22, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to unplug the blue and pink wires.
    Pergunte ao FixBot
    Comentar
  23. Xbox 360 E Motherboard Replacement: passo 23, imagem 1 %32
    • Lift the front end of the CD drive and take it out.
    Pergunte ao FixBot
    Comentar
  24. Xbox 360 E Motherboard Replacement, Motherboard: passo 24, imagem 1 %32 Xbox 360 E Motherboard Replacement, Motherboard: passo 24, imagem 2 %32
    • From the bottom of your Xbox, take your T9 torx screwdriver and take out all of the 11 mm screws labelled B1-7
    • Don't forget a screw on the side of the Xbox next to the power plug.
    Pergunte ao FixBot
    Comentar
  25. Xbox 360 E Motherboard Replacement: passo 25, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 25, imagem 2 %32
    • Flip the Xbox over and take out the heat sink plastic shield.
    Pergunte ao FixBot
    Comentar
  26. Xbox 360 E Motherboard Replacement: passo 26, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 26, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 26, imagem 3 %32
    • Unplug the red cable.
    • Unplug the blue cable.
    • Take the hard drive assembly by the long plastic arm and lift the entire thing out.
    Pergunte ao FixBot
    Comentar
  27. Xbox 360 E Motherboard Replacement: passo 27, imagem 1 %32
    • Flip the Xbox to the back and take your T10 torx screwdriver and take out the last four 6 mm screws labelled A1-4.
    Pergunte ao FixBot
    Comentar
  28. Xbox 360 E Motherboard Replacement: passo 28, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 28, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 28, imagem 3 %32
    • Back to the top of the Xbox, take out the metal and plastic insert.
    • Place two fingers in between the grooves in the metal body and the motherboard and pull up slightly. Do not pull up from the side with the plugs like the HDMI and internet.
    • As the motherboard comes up, switch to the left side and continue pulling the motherboard up.
    • Once that side of the motherboard is out, lift the rest of the motherboard away from the metal body.
    Pergunte ao FixBot
    Comentar
Conclusão
43 outras pessoas executaram este guia.
Bryce
Membro desde: 01/31/14
1.553 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-11, Amido Winter 2014 Membro de Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Membros
Autoria de 55 guias
4Comentários do guia
Where can I get the motherboard?
Derek Bullard - Responder Compartilhar
Need a motherboard.....
supergametime - Responder Compartilhar
How did you go finding one ? , I gotta get one I think , any chance u could get hold of me by email or I'm on fb ? , just wanna ask you about something with xbox memory n error cap
Daniel Leach - Responder Compartilhar
Would have been nice to include the heatsink removal procedure even if it is similar to the original 360. Also I have never had extra screws left over, yet I have 2 phillips screws left over which are mentioned nowhere in this guide. From no point of the teardown process could I find where they came from.
dot s - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 72
Últimos 30 dias: 424
Ao todo: 35,479
