Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
Fans Noise, Error: 4SNS/1/C0000008:TS0P--124
Hi.
I Add A SSD, Using: "OWC Internal SSD DIY Kit For All Apple 21.5" iMac 2011 Models w/ Tools", Then My iMac is Very Noise.
Apple Hardware Test Said This Error.
TG Pro Said: ODD 4350 RPM, CPU 4000 RPM.
Please Help me.
Update (04/20/2015)
Thanks A Lot.
This is the result on Temperature Gauge Pro.
Update (04/21/2015)
This is My new status:
Update (04/21/2015)
This is my (last) new status. Thank you Mayer! And every one!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
I've had to replace the optical drive fan in several of these. Some of the fans can be fixed by simply pushing on the center of the fan to move it back in place.
Esta resposta foi útil?
Pontuação 5
3 comentários:
You said "Hi, i push on the fan and the silence return, thanks, very much. But: On TG Pro: "Fan Diagnostics: These fans appear to be not working properly: Optical Disk Drive (ODD)" What can Do?" First restart the machine and run the diagnostics again. It's Apple part # 922-9120 If you get the same failure use this guide: iMac Intel 21.5" EMC 2428 Optical Drive Fan Replacement
por
will this also work for the iMac Intel 27"
por
Luis, sure it will!
por
JAIME, the problem is most likely related to the sensor of the optical drive fan. Replacing the sensor and/or the fan should resolve this. Try to start under Safe Boot mode. Follow this Apple TN" OS X: What is Safe Boot, Safe Mode?. Download and install this Temperature Gauge Pro. It should help show you what your sensors are telling you.
Pontuação 3
2 comentários:
Thanks A Lot. This is the result on Temperature Gauge Pro (below).
por
Boot my miMac on Safe mode and still is noisy.
por
Follow what OT has above
Also did you also get this: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade. You'll need it if you are swapping the old HD for a SSD drive.
Pontuação 3
2 comentários:
Thanks Dan, On what disk i need put this sensor?: HDD (Old Original, WD 500 GB) or SSD (New, Recent Adding: Samsung 850 Pro 256GB).
por
On the hard drive.
por
Boot my iMac on Safe mode and still is noisy.
Dan, on what disk i need put this sensor: HDD (Old Original, WD 500 GB) or SSD (New, Recent Adding: Samsung 850 Pro 256GB).?
Where can buy this fan or Sensor?
Pontuação 0
8 comentários:
It appears you have other issuers here.
por
Please tell me.
por
Did you open it and find which fan was making noise and push on the center of them to reseat it?
por
You only need the sensor I pointed you to if you swap out the HD for the SSD. Its a link so click on the blue to learn more about it.
por
Looking at your TG Pro output looks like the HD sensor is working so thats not the issue here. Are you sure you plugged in the sensors back (or correctly) when you disconnected the cables from the logic board to add in the 2nd drive cables?
por
Exibir mais 3 comentários
Adicionar a sua resposta
JAIME será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 4,160
