Ir para o conteúdo principal
Modelo A1502 / processador Intel Core i7 dual core de 2,6 GHz (Turbo Boost até 3,1 GHz) ou 2,8 GHz (Turbo Boost até 3,3 GHz) com 4 MB de cache L3 compartilhado.
replace HD model A1502
I just need to replace the HD on my model A1502. I need tools to remove the torx screws and I need to buy a new hard drive.
There are a lot of choices...which one do I use?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
2.6 GHz Core i5 (I5-4278U)
Intro Date: July 29, 2014 Disc Date: March 9, 2015
Order No: MGX72LL/A* Model No: A1502 (EMC 2875)
Subfamily: Retina Mid-2014 13" Model ID: MacBookPro11,1
Std RAM: 8 GB* Std VRAM: 1.5 GB*
Std Storage: 128 GB, 256 GB SSD Std Optical: None*
por
Adicionar um comentário
2 respostas
Solução escolhida
If you check you will most likely find a SSD stick instead of a hard drive. Please give us the last four figures of your serial number so we know your exact machine as there are 9 different A1502 models. Also, why do you want to replace it?
Esta resposta foi útil?
Pontuação 2
2 comentários:
G3QH need to repurpose but I must retain the old HD for legal reasons, hence need to put in new drive.
Thanks,
Paul
por
The MGX72LL/A configuration has 128 GB of flash storage. It is Apple Proprietary* (PCIe.) You will need to get it from Apple or possibly find one on eBay from someone that has upgraded. It will very high dollar, probably in the $750 range.
por
pwgailey, like mayer pointed out, it does not use a hard drive but an SSD. To replace it you will need a T5 TORX screwdriver and follow this guide.
Pontuação 2
1 comentário:
Thanks oldturkey03
por
Adicionar a sua resposta
pwgailey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 18,296
