PS4 will not power on
I just bought a used PS4 yesterday, and much to my horror it would not turn on when I brought it home. I set it up, and when I push power the blue light comes on for maybe a second, then shuts down completely. When I press it a second time, it beeps again (as it does when I touch "eject").
I've contacted Sony, but as it is out of warranty I'm not sure what they can do. Do any of you have any suggestions (other than banging it on my knee, which seems incredibly silly to me with an expensive piece of technology)?
Any help would be appreciated. I really hope I didn't just buy a $300 paperweight.
Esta pergunta é pertinente?
I have this problem to, when I press the power button it beeps and turns on for half a second and turns back off. When I press it again nothing happens. Please help, it's a brand new PlayStation 4 and is unused I've only played it for about a while 2 weeks total. Please help
por Austin Douglas
You can get a new power supply on amazon depending on the model for $50-$70 typically. Also some time just removing and seating the power supply back in all the way down can fix this issue. There is just enough wiggle room even when its screwed down for it to lift just a little giving you a bad connection. Check for the Model number on the bottom of the PS4 before purchasing a replacement power supply as the older models use a 4 pin and the newer ones use 5 pin. They are not cross compatible. Check the warranty also as once you remove the stickers covering the screws the warranty is void for the console. You can also replace other components this way as well if needed like the hard drive. Once open its a good idea to clean out any dust in there to prevent over heating.
por DragonKing Zul
I have this problem but nothing is happen when I press either buttons completely unresponsive. From u it unplugging do I just need a new power supply?
por Jon
Jon, if your PS4 is not under warranty, try this https://youtu.be/pszuueUTBrk
It worked for me after almost a year of searching for an answer. Do not take it COMPLETELY APART without trying this first.
por pigfantom
my ps4 will not turn on ive tried every possibility and nothing is working please help i have ran out of options does anybody know what to do
por kenyon billy
Mostrar mais 4 comentários
