Ir para o conteúdo principal
Fruta saborosa. Boa fonte de potássio. Amarela.
How can I tell?
I can't tell if I have a banana or avocado or maybe a dog? I might even have a mink pelt. I just wish there was a way to see if what I was holding and attempting to eat is actually a banana.
Esta é uma boa pergunta?
Pontuação 12
Adicionar um comentário
5 respostas
Solução escolhida
In case you are blind, bring in a monkey, wait 5 minutes, feel for which item is missing.
Esta resposta foi útil?
Pontuação 10
2 comentários:
What if it were a plantain?
por
Then it wouldn't be a banana.
por
Does the device emit a sound of any kind (while stationary)? Does it appear to have an on/off switch?
If it makes a sound, or has an on/off switch, it is NOT a banana.
Pontuação 5
is there a way you can post a picture of the device? it could be any of those. What are the specifications? or is it a knock off?
Pontuação 3
Bit in if it bits back it was the dog
Pontuação 3
Just make sure that the device is yellow and crescent moon shaped. If it has legs, then it's probably not edible in that state. If it's green, it may be an avocado. Hope this helps...
Pontuação 2
4 comentários:
if its green it also could be a cucumber, lime, or even a plantain. There are many options.
por
All of these green options are edible, however a lime is incredibly sour, and the anti-opening device in the lime will cause temporary blindness if the fluid is caught in the idea. A cucumber is extremely ovular. A plantain looks like a banana, but you may encounter bitterness. This is the anti-opening device.
por
the blindness will come from a lemon that has been died green.
por
That’s dyed green.
por
Adicionar a sua resposta
Yaxfer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 29
Ao todo: 1,249
