Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
Where is the location of the back light fuse 820-3476-a?
I recently received a Macbook Pro A1502 Retina liquid spill with logic board number 820-3476-a. Unit boots up but no back light. Does anyone know the location of the back light fuse and wled driver? Crazy thing I had it working fine however when installing the OS back light just went out. Also how many volts should I be getting on pin one?
Thanks
I think this might be the location of the fuse
Esta é uma boa pergunta?
Pontuação 2
3 comentários
Post some top and bottom view images of your logic board with your question. Adicionar imagens a uma pergunta já existente
por
yes F7700 is the fuse
por
its probably fine though, they rarely blow even under liquid damage. start probing U7700 pins 17,18 and 5 what voltages do you have
por
Adicionar um comentário
2 respostas
Pergunta mais útil
This is all wrong. You're talking about buying replacement chips without even having a schematic or a boardview. How can you know what to replace without even knowing where to measure??? How do you know the LED driver is bad?
Get a schematic and a boardview for 820-3476, then answer the following questions before further guessing.
1) Do you have 2.7v to 3v enable signal on pin 17 of U7700?
2) Do you have 5v on pins 5 and 18 of U7700?
3) Is R7733 0 ohms?
4) Is feedback network between R7731 and R7732 functioning properly? Traces to resistors good? Resistors themselves good?
5) What voltage do you have on backlight output, pin 1 of LCD connector? 0v? 12v? 20v? 27v?
Esta resposta foi útil?
Pontuação 7
3 comentários:
It's never the fuse on these. They are smart enough to turn off in case of a fault state.
por
I have a question concerning this board I have the same 820 3476 a and I have an amber light all the time with battery or without and no power on can you tell me where to start with this the board looks very clean I had to replace the EFI chip because the board did not have one when I bought it doesn't need flashing how to do that Thank you for your help
por
Hi
I have got 0V on pin 17 of U7700!!!
can you please lead me what should I do?
por
allenzabbal, you are correct. The reference designator is F7700 and it is a 3A 32V fuse in a 0603 package and the driver is U7700 and it is a LP8548B1SQ_-04 IC.
Pontuação 2
3 comentários:
I checked the fuse and it is not open. Can the wled driver fail without and the fuse still ok? Do you know how may volts I should get on pin 1 on the lvds connector? thanks again.
por
also where can I get the backlight package LP8548B1SQ? Would a LP8545SQ package work?
https://store.ti.com/LP8545SQENOPB-High-...
Thank you oldturkey03 for your help
por
zzz AKA Louis Rossmann know his stuff along with oldturkey03
por
Adicionar a sua resposta
allenzabbal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 4,190
