Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone 5s will not turn on or charge?
My sister in laws Iphone 5s was given to me to repair as it will no longer turn on. She states that randomly over the past few months the phone would just turn off and now it will not turn off or charge when connected. I have tried power/home, different chargers but am without luck. Yesterday it turned on for a brief while but had a blank yellow screen. This phone is just outside of warranty and it is not jailbroken. Does anyone have ideas to how to fix this?
Esta é uma boa pergunta?
Pontuação 1
6 comentários
Itunes or computer will not detect phone
por
I have replaced the battery but it didnt make a difference, didnt even turn on with a new battery inside
por
Next would be the lightning connector.....
por
Would just think that the Battery change would have brought a little life to the phone at least temporarily. Will order Lightning connector and report back in a week.
por
If you have nothing else left to eliminate? And possibly the new battery needed a good charge, I've had some arrive which needed a 30 minute charge before it came to life.
If itunes won't recognise the phone, the charging port may well be dead?
What is strange is the yellow screen?
If she's anything lie all the women I know, did she use the phone in a steamy bathroom? May have some sort of water damage without the indicators going pink, would have no idea how this could be tested though?
You know anyone with a working 5s you could chuck a battery in which you know has charge in it?
por
Exibir mais 1 comentário
Adicionar um comentário
4 respostas
Pergunta mais útil
Matthew, does not charge and does not get detected by iTunes or your computer lead me to suggest a new lightning connector. Yes, you can also change the battery, but ultimately it sounds like the connector. Use these guides to replace it.
Esta resposta foi útil?
Pontuação 1
2 comentários:
lightning replaced. No change
por
What voltage do you get on your battery connector when you plug the phone in?
por
Tried a new battery? I've slightly damaged a battery when doing a colour conversion on a 5c (is was stuck Down good) randomly turning off. Found it was the battery.
Pontuação 0
1 comentário:
Replaced Battery = no change
por
Charging dock....
Pontuação 0
1 comentário:
Don't understand how this is relevant?
por
I see a mix of problems.
Please help clarify:
Was, Randomly turning off
Now, will not turn off
Now, will not charge
Is this correct?
Sounds like there are several possible problems. Could be only corrupt OS, or only failing motherboard, or failed charging port with broken power button. It's hard to tell without trial and error to find out what's actually working.
Pontuação 0
1 comentário:
Replaced lightning and battery and it now charges. however will randomly turn off with blue screen and will boot loop blue screen randomly then turn back on. very inconsistent. I have done restore which takes multiple attempts of blue screen before it will complete.
por
Adicionar a sua resposta
Matthew será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 788
