Ir para o conteúdo principal
A Nikon Coolpix L810 é uma câmera digital compacta e acessível que oferece recursos do tipo "aponte e dispare", zoom de longo alcance e gravação de vídeo. Ela faz parte da série L da Nikon e foi lançada no início de 2012.
How do I fix the lens cap error?
There is a lens cap error asking to remove the lens cap even though the it is already off.
Esta é uma boa pergunta?
Pontuação 14
2 comentários
My lens is locked in the fully extended position, I also get the lens cap error.
por
mine is in the full zoom position and I get the lens cap error is there any way of fixing it?
por
Adicionar um comentário
5 respostas
Pergunta mais útil
My camera got stuck on “turn off, remove lens cap.” Error mode, so i tried the forcibly hitting camera by dropping it to carpet floor about 2-3 times (soft surface) and immediately removed error! Thanks!
Esta resposta foi útil?
Pontuação 3
I had the same problem, so what I did was to tap he side of the camera couple of times and switch on the camera. It might not work first time, but it cleared the error message
Pontuação 2
1 comentário:
Thank you Robert! I placed a book on a countertop and hit the camera forcibly against the book approximately 20 times and it worked eventually. I tired to hit all sides of the camera. It cleared the error message. All fixed now!
por
Here are some possible ways to fix this problem based off of relevant researches,
1) There could be some dirt, sand, or small materials blocking the way for the lens to extend so you would need to take a microfiber cloth and clean as much as possible around the lends barrel. Another way could be to forcibly blow out any obstructions around the lens barrel.
2) Turn the power off remove batteries and wait one minute then replace the batteries with a brand new set, once this is complete turn the camera back on while holding the functions button (the ok button). Should that not work turn camera back off and remove memory card and repeat the process.
3) Plug in the AV (audio/video) cable, the reason so is because this will provide more power for the camera lens to extend and refocus
4) Placing the camera on a hard surface, face the lens towards the ceiling, and hold the shutter button while you press the power button. The idea for this process is to try realigning the lens back into their personal slots.
For more information click here to Refer to the troubleshooting page.
Pontuação 1
1 comentário:
Thanks. That worked for me
por
This is probably the cause of stability. But it is best to replace the lens.
Pontuação 0
The best and most logical solution I have found online was to clean the lens sensor.
The lens sensor is located around the casing of the lens that potrudes when the camera is activated.
Using a soft cloth with some isopropyl alcohol, or blowing around the edge usually solves the problem.
Imagem
Please enlarge the picture to see the arrow pointing to the lens sensor location.
Pontuação 0
Adicionar a sua resposta
Bo Cheng será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 37
Ao todo: 22,306
