Ir para o conteúdo principal
Uma câmera CMOS com capacidade de Wi-Fi e NFC, lançada inicialmente em março de 2013. Identificada pelo número de modelo EV-NX300ZBQUUS.
Why does my camera show Error 01?
When I turn my camera on, it automatically gives me "Error 01." I've restarted it multiple times already, but that does not seem to work. Does anyone know how to fix this?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi, Ellie.
On most Samsung cameras, the NX300 included, this means that there's a connection problem between the camera and the battery; usually the result of dirt in battery chamber or on the battery's contacts that prevent the camera from receiving the proper voltage needed to fully operate. Start by powering the camera off and removing the battery. Next, make sure that the contacts on both the battery and the camera are clean and in good state. You may use a cotton swab dipped in rubbing alcohol to clean the inside of the battery chamber. Once everything is good to go, carefully replace the battery and power the camera back on.
Should there be damage on any parts of the battery, consider acquiring a new one. You can find additional support on some common battery problems on the NX300's troubleshooting page.
Hope everything goes well!
Esta resposta foi útil?
Pontuação 1
2 comentários:
I did. But I have got another problem. I can shoot only for once, after that the lens can not detect the object (blank). I can shoot again if I turn off the camera and turn on agian. IT's only for once shoot. What should I do?
por
I have this same issue and it's been over 2 years now. I haven't been able to resolve this. have you been able to get any help?
por
Adicionar a sua resposta
Ellie Guadron será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 4,951
