I have a 5E code on my microvave
I have a 5E code on my oven it will not work it has power the inside light goes on bu nothing works
Esta é uma boa pergunta?
Keyboard error code. Unplug it for 30 minutes to allow it to reset then try plugging it back in.
Esta resposta foi útil?
It is a temporary fix.... its just that you have to keep doing it again. I'd like to get to the root of the problem...to know what is the cause.
Most likely in the keypad or perhaps the control board.
What is the model number of the oven?
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 4,706
2 comentários
sometimes it works. Most times it says set date/time then quits .
Other times it goes to an "SE" message & stops & freezes!
por Brian Northcott
It is a model # Kenmore 401.85042010 Ser # 143MM01551
por Brian Northcott
