Ir para o conteúdo principal
O Skullcandy Air Raid é um alto-falante Bluetooth portátil sem fio lançado em 15 de novembro de 2013, que transmite música de qualquer dispositivo habilitado para Bluetooth.
Why wont my device charge?
I have checked my wall outlet and it works perfectly fine with charging other plug-in devices, it just seems to be a problem with my Air Raid. What should I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
If the outlet is working and your device is still not charging, you may have a bad USB port. If your device only charges when the plug is held at a certain angle, will not plug in all the way, or has visibly bent/broken pieces inside the charging port, you should replace the USB port. If you have left the Air Raid charging for a long time, but the battery dies quickly after unplugging it, you may need to replace the battery.
Esta resposta foi útil?
Pontuação 1
2 comentários:
You should try going to Skullcandy Air Raid Troubleshooting for more troubleshooting help
por
Where do i purchase a new battery?
por
@Sasha Nevin, SAME!! IDK what to do about it, but it is really annoying. I've had to use earphones (the ones u stick in ur ear) and was trying to get away from those, however it just won't charge! I also tried charging it through my computer, therefore it still didn't charge
Pontuação 0
Adicionar a sua resposta
Sasha Nevin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 21
Ao todo: 5,382
