Ir para o conteúdo principal
Portable and simple laptop released on April 2007 by Hewlett-Packard.
How easy is it to swap the wifi card?
hello,
this isnt repair related yet but long and short i am buying a hp mini 311 either entirley stock if the wireless is easily upgraded
if its hard i am going for it configured
RAM and HDD can be upgraded if needed
CPU is fine for a netbook
how hard is it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
it should be no problem for you
here is a link to a teardown and some wwan experiments ;-)
Esta resposta foi útil?
Pontuação 1
2 comentários:
Are you planning to make a hackintosh out of it ? or why do you want to change it ?
por
ok, compatible isn't the issue - we are talking about a windows machine - you can also use the mini pcie wifi card from a MacBook and i could bet that the cheap dell wifi/wwan/br stuff will also work in this unit
por
Adicionar a sua resposta
Nick será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 2,964
