Ir para o conteúdo principal
Repair information on tablets manufactured by Dell.
Screen is cracked but now only half of screen works
So, only in a part is there a crack, but I have problems with the right half of the screen. The left side moves things when I touch it as it should do, but when i go to the left side, nothing. it doesnt work. It looks normal and everything. the screen is pretty clear, but i dont know what to do.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Haley, you did not tell us which tablet you have. From your description of the symptoms, it sounds like your digitizer has failed because of the crack. It does not matter what side is cracked, it will ruin the continuity of the circuitry in the digitizer. Replace it to repair the function.
Esta resposta foi útil?
Pontuação 3
1 comentário:
It is a 8 inch Dell venue 8 3830 tablet
por
Adicionar a sua resposta
Haley será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,061
