Why does the projection clock "on" button keep turning off?
Whenever I turn the projection clock button to the "on" position, it moves back to the "off" position and will not stay on.
Esta é uma boa pergunta?
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 412
2 comentários
After some research, I discovered that the unit needs to be reset.
Resetting process:
Remove batteries and disconnect adapter for 15 minutes.
Reinstall batteries and reconnect adapter.
Hold reset button for 5 seconds located in the battery compartment or on the back of the unit.
(A paper clip or pin will be needed to fit into the hole for the reset button.)
por Kathy Rowley
Projection Clock RM318PA Troubleshooting.
por Kathy Rowley
