Ir para o conteúdo principal
Released Pre-Fall 1997, identified by model number RM318PA
Why does the projection clock "on" button keep turning off?
Whenever I turn the projection clock button to the "on" position, it moves back to the "off" position and will not stay on.
Esta é uma boa pergunta?
Pontuação -1
2 comentários
After some research, I discovered that the unit needs to be reset.
Resetting process:
Remove batteries and disconnect adapter for 15 minutes.
Reinstall batteries and reconnect adapter.
Hold reset button for 5 seconds located in the battery compartment or on the back of the unit.
(A paper clip or pin will be needed to fit into the hole for the reset button.)
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi Kathy,
Sometimes the on/off switch can get a bit loose and you might need to snap it back in place. See the guide linked below!
Oregon Scientific RM318PA Power Switch Replacement
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kathy Rowley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 516
