Ir para o conteúdo principal
Oregon Scientific RM318PA Power Switch Replacement
O que você precisa
  1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: passo 1, imagem 1 %32 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: passo 1, imagem 2 %32 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: passo 1, imagem 3 %32
    • Hold clock so that the clock face is facing away from you.
    • Using your thumbs, push up on the battery cover.
    • Once battery cover is removed, pull down on AC Adapter Jack.
    Pergunte ao FixBot
    Comentar
  2. Oregon Scientific RM318PA Power Switch Replacement, Batteries: passo 2, imagem 1 %32
    • Use one hand to stabilize the clock.
    • Using your other hand, push batteries toward spring and pull out at an angle.
    Pergunte ao FixBot
    Comentar
  3. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: passo 3, imagem 1 %32 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: passo 3, imagem 2 %32 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: passo 3, imagem 3 %32
    • Use a Plastic Opening Tool to pry off the silver casing on the back.
    • Pry at the top of device.
    • Once the back is open at the top, pry at the side of the device closest to the battery compartment.
    • On/Off switch should come off with casing.
    Pergunte ao FixBot
    Comentar
  4. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: passo 4, imagem 1 %32 Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: passo 4, imagem 2 %32
    • Insert switch into slot as shown in picture. Push in until you hear a "click."
    • Replace the back of the clock by pressing cover back into place.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Maxine Holden
Membro desde: 10/27/14
500 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 1,860
