Ir para o conteúdo principal
Um smartphone 4G fabricado pela Motorola em 2011. Distribuído pela Sprint.
Why is my device not turning on?
I try to turn the phone on and it won't make any indication that it is on and running.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
the phone is turning on and off but the apps are not opening.The application Home (processcom.home)has stopped and is continually on the screen. Please assist.
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
If the phone does not turn on try these options:
  • Check if the battery is charged. If the battery is faulty and does not take in charge, the phone will not turn on.
  • If the battery does not turn on after charging then your battery may be faulty and you should replace the battery.
  • If the phone still does not turn on after changing and charging a new battery, then the motherboard may be faulty and should be replaced.
For more help refer to: Motorola Photon 4G Troubleshooting Guide
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jennifer Osterman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 1,068
