Ir para o conteúdo principal
A 4G smartphone manufactured in 2011 by Motorola. Distributed by Sprint.
7 Perguntas Visualizar todos
Why is my device not turning on?
I try to turn the phone on and it won't make any indication that it is on and running.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
the phone is turning on and off but the apps are not opening.The application Home (processcom.home)has stopped and is continually on the screen. Please assist.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
If the phone does not turn on try these options:
  • Check if the battery is charged. If the battery is faulty and does not take in charge, the phone will not turn on.
  • If the battery does not turn on after charging then your battery may be faulty and you should replace the battery.
  • If the phone still does not turn on after changing and charging a new battery, then the motherboard may be faulty and should be replaced.
For more help refer to: Motorola Photon 4G Troubleshooting Guide
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jennifer Osterman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 739
