Ir para o conteúdo principal
A rotary tool made by the Dremel company. It is model number 395 and runs at 5000-35,000rpm.
Why is my Device not turning on?
I plugged My MultiPro in and no matter what I do it will not turn on. The bit will not rotate and the device seems to not be getting power at all. Can this be fixed?
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes, this problem can be fixed. Ways in which you can fix your dremel and get it to power on are, Making sure the dremel is plugged in, make sure the brushes are properly cleaned, and make sure the stator wires are making a connection with the connector.
Dremel MultiPro 395 Troubleshooting
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Matthew Satton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 2,481
