Ir para o conteúdo principal
Modelo A1369, processador de 1,6, 1,7 ou 1,8 GHz, armazenamento flash de 64, 128 ou 256 GB
FaceTime camera not connected. Hardware issue?
I have a 2011 MacBook air whose built in FaceTime camera doesn't work and is not recognized by any app or the system profiler. I have attempted the following to resolve the issue however I have no success.
1. SMC & PRAM resets
2. Disk utility - repair disk and repair permissions
3. OS X reinstall - erased and reformatted and reinstalled.
4. Apple Hardware diagnostics test
5. Use of new profile.
I am thinking this is a hardware issue however I don't recall anything going wrong with the machine. Everything else works fine and the camera worked well previously too. Note: the ambient light sensor that's next to the camera doesn't function either.
Any one have any ideas? I have never taken the laptop apart but I don't mind doing it if I have to. Can the camera/light sensor be replaced or does the whole screen assembly have to be replaced?
Any advice/tips are appreciated.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
There is a cable connection to the I/O board that might have worked loose. Review the IFIXIT guide MacBook Air 13" Mid 2011 Logic Board Replacement Step 12.
The other possibility it the camera unit has gone bad. Which will require replacing the full lid assembly unless you can find the part alone.
Esta resposta foi útil?
Pontuação 3
5 comentários:
Not the logic board, the camera is connected to the mini board.
por
The connection to the I/o board seems firm and fine. Could it be the I/O board? The ambient light sensor doesn't work either so I am thinking it may be the I/O board, unless the ambient light sensor is part of the camera? Replacing the LCD assembly would be too costly and might as well get a new machine for that sort of money. Any thoughts?
por
Is there any dents in the cover? If so the I/O board cable could be damaged otherwise you can try replacing the I/O board.
por
There are no dents at all on the machine. Yes I mihh have to resort to replacing the i/o board.
por
omg thank you so much it worked ! I dis an reconnected the cable of step 12 and it fuc*$*§' works :)
por
This same thing happened to me. The software version 10.10.5 will, over time, cause the FaceTime camera not to work. I simply updated my computer then I had no further issues. Let me know if this helps. If you are past 10.10.5 (Yosemite) please let me know.
Pontuação 0
3 comentários:
I updated to High Sierra and it's still not working. I plugged the cable in tightly as well. Any advice?
por
Reseat the cable.
por
Completed all steps and still no go
por
Adicionar a sua resposta
Viral Patel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 13,103
