Ir para o conteúdo principal
Primeira geração da Kawasaki Ninja 500.
How to clean the carbs
Hi I'm new to motorcycles. I just got a 1993 Kawasaki ex 500. The guy I got the bike from said he knows the carbs need to be cleaned. Can someone please tell me how to do this. ? This is my first bike so I have no clue what to do. And a repair shop wants 400 and up. And I don't have that. To spend right now. Any help would be great thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Chris Hilliard, take a look on here. different bike, same idea. You can find step-by-step instructions on here. I'd suggest you get a carb overhaul kit and get to it. take your time, it is not as easy as it seems. The numbers for your Kawasaki carbs are 15002-1492 LH 15002-1493 RH. Armed with that you should find a rebuild kit relatively easy. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hey, thank you so much. I wrote this down. And I'll check the site. Thanks so much. I can't wait to have her up and running.
por
https://ninja250.org/ = THE Bible for the 250cc-300cc Kawasaki’s. Good advice for all motorcycles also.
Pontuação 0
Adicionar a sua resposta
Chris Hilliard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 2,591
