Ir para o conteúdo principal
A Windows phone known for its camera capabilities. Also known as Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
Memory Upgrade from 32GB to 64GB
I have a Nokia Lumia 1020 GB 32GB which is the usual standard in many countries except that
64GB is sold in certain EU countries. Is there a way if I can upgrade the memory
from 32GB to 64GB rather than buying a new phone. Any input would be
appreciated. thanks
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
anjinsan, not unless you can a. get your hands on the memory IC's and b. have a reball station as well as the proper stencils and solder balls. The memory IC's are a BGA and can not be changed easily. So for the normal DIY'er the answer will be "no". Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
1 comentário:
That's what I thought but wanted to see if there was another option.
thanks for confirming.
por
Hi how can I find out what memory is my phone Nokia Lumia 1020 thanks
Pontuação 0
1 comentário:
Instructions on how to find them are here: http://www.windowsphone.com/en-au/how-to...
por
Adicionar a sua resposta
anjinsan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 5,494
