Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Any help identifying iPhone 4 (CDMA) component?
Does anyone know which smd component this is?
It's in an iPhone 4 (Verizon - CDMA) that sustained some water damage (which I cleaned). Following this the camera simply wouldn't work anymore, leading me to assume it could be this component (due to how corroded it still is after cleaning board).
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
1di0t (;-), that is reference designator L11, which is a 3-terminal Filter, SMD Array and it is used for noise removal from high-speed signal lines. A TDK MEA1608PH270T would be a good match. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Found it. Thank you very much man!!
por
Adicionar a sua resposta
1di0t será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 169
