Ir para o conteúdo principal
A terceira geração de tablets coloridos Nook de 7 polegadas da Barnes & Noble; não confunda com o Nook HD+ de 9 polegadas.
Need a source for replacement battery.
I have searched for a replacement battery for the Nook HD to no avail. All that can be found are not for the HD. None have the 4000MHA, 14.8 Wh rating.
Does any one know of a source, other than B&N (who won't sell the battery) ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
jmbiii3, the battery number for your Nook HD is BNA-B0002. the battery appears to be available right here and here as well. Of course, always check with the vendor. If you are truly fixed on the 4000mAh you can check on here
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks ! The battery in the HD is a 4000mAh and I would like to keep it at that rating. I'd order the one you mentioned last, but can't quite read the order info. LOL
por
Here you go!
https://www.newpower99.com/SearchResults...
Pontuação 0
Adicionar a sua resposta
jmbiii3 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 2,518
